Measurement Studio for VC++
Is it possible to use the ComponentWorks or ComponentWorks++ controls across multiple threads?
--Chris
(5,506 Views)
Chris:
Currently, the Measurement Studio controls can only be accessed from the thread in which they were created. This limitation will be removed in a future release of Measurement Studio.
Until then, you can use DataSocket or Windows messages to get around this limitation. For instance, you can setup a user event to update the UI controls in the main thread, and then trigger that event in another thread. I've written a short example that demonstrates this using Windows messages. The readme.txt file in this example explains how the code works and how you can re-construct it from scratch.
http://zone.ni.com/devzone/devzoneweb.nsf/opendoc?openagent&24C350515009D6A1862569AC0073ACC6&cat=61B119A9F74ADC07862568C50070CE22
Chris Wood
Nati
onal Instruments
(5,506 Views)
