Measurement Studio for VC++
LinFit
I have two C++ arrays for example:
double *array1 = [1.2, 1.5, 2.0, 3.5];
double *array2 = [6.0, 7.0, 7.5, 8.2];
how do I pass this arrays to LinFit? LinFit takes
variants as arguments.
Thanks.
(3,791 Views)
Sorry, forgot to mention that LinFit is a method of CWStat.
(3,791 Views)
Since you're using C++, you might want to take a look at the CNiMath class from Measurement Studio for C++. It has a LinearFit method that would be easier to use with C++ data types than CWStat.
- Elton
(3,791 Views)
I found the solution to my problem and it was easy! (but it drove me nuts to find it!)
simply, declare a COleVariant, set it's vt to VT_BYREF | vt_R8 and set its pdblVal to the array. See code below:
COleVariant x;
x.vt = VT_BYREF |VT_R8;
V.pdblVal = array1;
// do the dame for array2
(3,791 Views)
