Measurement Studio for VC++
Mapping CNiGraph events to CView
I need to add a CNiGraph on a view. I add the control on the view using
m_niGraph.Create( pszCaption , WS_VISIBLE , *pRect , this , IDC_NIGRAPH );
Now i need to map the Key Down and Cursor Move events to the view. Please tell me if u know a way to do that.
(3,252 Views)
Hello
With MDI and SDI documents, you cant use the wizard to generate the event maps for you. This is something you have to do manually. I have attached an example of this, but also check out the following links. Here and here are some handy references that walk you thru the process of adding the event handlers.
I hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(3,252 Views)
Thank you for your solution. It is realy the one i needed. Hope this helps others too.
(3,252 Views)
