Measurement Studio for VC++
Measure voltage by event with AT-MIO 64E3
Thanks Chris for your reply,
I haven't CWAI controls in to Project->
Add->Components and Controls.
Where can i found it.
Thanks so much.
Best Regards.
(3,727 Views)
They install with Measurement Studio or NI-DAQ. You need to install ComponentWorks from the Measurement Studio CD or install Visual Basic support from NI-DAQ.
Best Regards,
Chris Matthews
Measurement Studio Support Manager
(3,727 Views)
Hi Chris,
Thanks.
When i compile your prog, i have an error: can't open file niall.h.
Where can i found it?
You said in your last answer that i need to install ComponentWorks from the Measurement Studio CD. I haven't this CD. Do you know if NI give this CD free.
Have a good day.
(3,727 Views)
That example is written with Measurement Studio. Measurement Studio includes development tools for for ANSI C, Visual C++, and Visual Basic developers. That is what this discussion forum is setup for so I mistakenly assumed you had it. The DAQ ActiveX controls are the only controls that are available for free. All the rest of them (User Interface, Analysis, etc.) are included in Measurement Studio. Since you don't have it, then you can't use the example I sent, but you can still use the CWAI control. Add the control to a project and then you can look at the example's CPP file to see how it is used.
Best Regards,
Chris Matthews
(3,727 Views)
