Measurement Studio for VC++
Memory leak in Gabor spectrogram function?
HI,
Is anyone aware of a memory leak in the SptRealFastGaborSpectrogramEx function of the signal processing toolkit? I have version 7.0.1.  I have debugged everything else and cannot seem to find anything in my code.
Thanks!
Marc
(5,173 Views)
Marc,
I responded VIA email but I will also discuss this here.
Since you are using a C++ environment, there may be problems with calling these functions (though technically they should work). I am unable to replicate this issue in CVI (what this toolkit is made for) however, could you try to use the non-Ex version of this function? If this still does not work, please email me a small example of this behavior in a small project and I can try to see if we can locate the problem.
Brandon Vasquez | Software Engineer | Integration Services | National Instruments
(5,163 Views)
