Measurement Studio for VC++
NI 9201 voltage range
Dear All,
Can I program the voltage range of NI 9201/NI 9221 even though there is only 1 nominal voltage range?
Anyway there is C function DAQmxCreateAIVoltageChan.
I am using cDAQ-9172 & Visual C++.
Thanks and regards,
A
(7,405 Views)
Hi angelmcdoggie,
You are correct that there is only one input range for the NI-9201/9221, according to the specifications. Unfortunately, this device does not have a programmable-gain amplifier, and thus you will only have the single range of ±10V for the 9201 or ±60V for the 9221. Setting the maximum and minimum input value parameters of the DAQmxCreateAIVoltageChan function to anything less than 10V and greater than -10V, respectively, will still yield a range of ±10V. Hope this helps,
Daniel S.
(7,376 Views)
Thanks for the information, Dan.
Robot Happy
(7,371 Views)
