Measurement Studio for VC++
NI PCIe-1433 Camera Link frame grabber programming using VC++
Hello, I have a Basler Camera Link-compatible camera and they use the NI PCIe-1433 Camera Link frame grabber as the image acquisition device.
Right now, I want to develop some applications on that camera and need to do programming on the NI PCIe-1433 by VC++.
So I want to know where I can find the software development kit for the NI PCIe-1433. For example, I can control the camera to grab the image by using the different functions(such as imgGrab(), or somthing like that ) from that software development kit.If there are some sample code that would be better.
(7,356 Views)
Hi Wrsbj,
The IMAQ functions that you mentioned are contained in the IMAQ driver, which is used to acquire from Camera Link frame grabbers. I would also check the compatibility chart, to make sure that you get the version you need. As for example programs, you can take a look at this KnowledgeBase article concerning building and running the IMAQ examples in VC++.
David S.
(7,328 Views)
Thank you  for your tips. While I can not access the " this KnowledgeBase "
In  the webside "http://digital.ni.com/public.nsf/allkb/3139EBE28D28CFD6862567C500093C27?OpenDocument"
It tells  me that "
Error
You are not authorized to view this document
So I cannot  get the examples about the C++ development kit .
Can you help me  to access the sources, or give me the examples .
Best Wishes for  you !
MailBox: defender2009@163.com
(3,836 Views)
