Measurement Studio for VC++
NI PCIe-6321, PCIe-1433 - RTSI connected use
I've set up the trigger. However, the picture does not come out properly.
Is there another source coding method? (C++)
Image marked as vtk (500x1024)
Message 1 of 14
(4,454 Views)
Configuration has already been finished?
Real-Time System Integration (RTSI) and Configuration Explained
I guess timeout error broke out. How are you configuring terminal between PCIe-6321 and PCIe-1433?
Which is master device, what signal are you sharing?
For example as below.
PCIe-6321 (PFI1) -->  start trigger --> PCIe-1433(TRIG)
In above case, 1433 should be waiting start trigger before 6321 sends the signal.
Certified LabVIEW Developer
GCentral
Message 2 of 14
(4,443 Views)
Four configurations have been completed.
DAQmxErrChk(DAQmxCreateTask("AOCh0", &m_BScanOutTask));
DAQmxErrChk(DAQmxCreateTask("AOCh1", &m_CScanOutTask));
DAQmxErrChk(DAQmxCreateTask("C0CH", &m_CAMTimmingTask));
DAQmxErrChk(DAQmxCreateTask("C1CH", &m_MasterTrigTask));
DAQmxErrChk(DAQmxCreateCOPulseChanFreq(m_MasterTrigTask, "Dev1/ctr0", "", DAQmx_Val_Hz, DAQmx_Val_Low, 0.0, CounterFrequency, 0.8));
DAQmxErrChk(DAQmxCfgImplicitTiming(m_MasterTrigTask, DAQmx_Val_ContSamps, XRange));
DAQmxErrChk(DAQmxSetStartTrigRetriggerable(m_MasterTrigTask, TRUE));
DAQmxErrChk(DAQmxCreateCOPulseChanFreq(m_CAMTimmingTask, "Dev1/ctr1", "", DAQmx_Val_Hz, DAQmx_Val_Low, 0.0, CounterFrequency, 0.2));
DAQmxErrChk(DAQmxCfgImplicitTiming(m_CAMTimmingTask, DAQmx_Val_FiniteSamps, XRange));
DAQmxErrChk(DAQmxSetStartTrigRetriggerable(m_CAMTimmingTask, TRUE));
DAQmxErrChk(DAQmxConnectTerms("/Dev1/Ctr1InternalOutput", "/Dev1/RTSI0", DAQmx_Val_DoNotInvertPolarity));
DAQmxErrChk(DAQmxCfgDigEdgeStartTrig(m_CAMTimmingTask, "/Dev1/Ctr0InternalOutput", DAQmx_Val_Rising));
DAQmxErrChk(DAQmxCreateAOVoltageChan(m_BScanOutTask, "Dev1/ao0", "", -10.0, 10.0, DAQmx_Val_Volts, NULL));
DAQmxErrChk(DAQmxWriteAnalogScalarF64(m_BScanOutTask, 1, 10.0, GarvoBMInitBuffer, NULL)); //x axis mirror initial position shift
DAQmxErrChk(DAQmxCreateAOVoltageChan(m_CScanOutTask, "Dev1/ao1", "", -10.0, 10.0, DAQmx_Val_Volts, NULL));
DAQmxErrChk(DAQmxWriteAnalogScalarF64(m_CScanOutTask, 1, 10.0, GarvoCMInitBuffer, NULL)); // y axis mirror initial position shift
DAQmxErrChk(DAQmxCfgSampClkTiming(m_BScanOutTask, "", CounterFrequency, DAQmx_Val_Rising, DAQmx_Val_FiniteSamps, XRange));
DAQmxErrChk(DAQmxSetStartTrigRetriggerable(m_BScanOutTask, TRUE));
DAQmxErrChk(DAQmxCfgDigEdgeStartTrig(m_BScanOutTask, "/Dev1/Ctr0InternalOutput", DAQmx_Val_Rising));
DAQmxErrChk(DAQmxWriteAnalogF64(m_BScanOutTask, XRange, 0, 10.0, DAQmx_Val_GroupByChannel, GarvoObuffer, NULL, NULL));
Trigger is configured like this.
Message 3 of 14
(4,437 Views)
It seems that there is no critical problem.
The device export counter signal by "DAQmxConnectTerms" function.
If your code is no problem, execution order might cause a problem.
Before starting counter task, has PCIe-1433 been waiting state?
GCentral
Message 4 of 14
(4,391 Views)
How can I tell if the 1433 is on standby? I'm not sure because it's my first time.
The video came out, but I just decided that the trigger was wrong because it was not the desired video.
In addition, some changes were made to the Camera option in NI-MAX.
ex) The image is output as vtk after cuda cuffing.
Message 5 of 14
(4,380 Views)
Press "Snap" button on NI MAX. Image doesn't show up yet.
After you start DAQmx program, image should be shown up, right?
GCentral
Message 6 of 14
(4,369 Views)
Thank you for answer.
If the test does not trigger the DAQ program, NI-MAX generates a time out.
However, when I trigger on a DAQ program, no time out error occurs in NI-MAX, but the image does not appear and is displayed in black and white.
Message 7 of 14
(4,366 Views)
In addition, the camera settings are set to Internal as shown in the image below.
Message 8 of 14
(4,350 Views)
No timeout error implies that trigger detection on PCIe-1433 is success.
Let's move our sight to why camera doesn't return expected image.
When you configure the camera with no trigger, does it return expected image?
If so, this problem is caused by trigger configuration.
GCentral
Message 9 of 14
(4,334 Views)
Without the trigger, the desired image will not come out.
6321, 1433 Is there a command to sync two?
Message 10 of 14
(4,331 Views)
