Measurement Studio for VC++
NIDAQmx: how to simultaneously acquire channels at different sample rates?
I have a PCI-6229 (M-series card). It has an advertised throughput of 250K/sec. I'd like to configure the card to simultaneously sample eight (8) AIN channels at 25K/sec, and none (9) AIN channels at 5K/sec. This results in a usage of about 245K/sec out of the available 250K/sec, which seems "do-able". But how do you setup the task(s) in NIDAQmx to do accomplish this? Are there any examples (I'm using the ANSI-C API) which illustrate how to do this?
I can't just set all 17 channels to 25K (and decimate the data for the slow channels), because there is not enough bandwidth. I was also unable to setup two tasks (one for high-speed, one for low-speed) because I get an error when I start the
second task. Is there another way to accomplish this?
Thanks in advance for any help!
(3,609 Views)
Greetings,
I would take a look at this KnowledgeBase that describes the process between doing this task.
http://exchange.ni.com/servlet/Redirect?id=12678799
Unfortunately, a text base example program does not currently exist, but if you have questions we'll do our best to help you out.
Anuj D.
(3,609 Views)
I apologize, I posted the wrong link!
The correct links is here:
http://digital.ni.com/public.nsf/websearch/96FD2F4685065C7686256F25006EE8DE?OpenDocument
Anuj D.
(3,609 Views)
