Measurement Studio for VC++
NonLinearFit problem
I have a problem using the 'NonLinearFit' method :
I have an application that is compiled under VC++ 6.0 (with Ni Measurement Studio 6) and VC++ 2008 (with Ni Measurement Studio 8.6.1). This application needs to compute a gaussian fit from gathered datas. The VC6.0 version works fine, but I encounter problems with the 2008 version which is not able to give me the best gaussian coefficients (whereas the VC6 do) (especially the 'center' ie the X value for which the Y is maximum).
If anyone has an idea...
Thank you
(5,880 Views)
Hello Fabien,
Do you still have a problem with this ? Could you please send us a simple example to reproduice the behavior of your code ?
Yannick.
(5,758 Views)
