Measurement Studio for VC++
NullReferenceException - AnyCPU-debugging with 64bit-compile
we run into an „System.NullReferenceException“ with StackTrace „at NationalInstruments.Internal.SlcpHelper.d()“ when we start AnyCPU-debugging with 64bit-compile from Visual Studio. See attached screenshot.
The same application compiled with „prefer 32bit“ (in the WPF-Project-Settings) starts without any exception.
WPF-Application (.Net-Framework 4.8 with licenses.licx) to show the UserControl.
C#-Library (.Net-Framework 4.7.2 with licenses.licx) with the UserControl containing the MixedGraph.
Versions:
Measurement Studio 2019: 2019 f4.
(3,019 Views)
Hi there,
This looks similar to the case that you are experiencing:
https://forums.ni.com/t5/Measurement-Studio-for-NET/Measurement-Studio-Application-deployment-issue-...
(2,847 Views)
