Measurement Studio for VC++
Obj. Error when compiling multiple C odules ncluding the nidaqex.h header file
This is a C implementation.
I have two modules. The main program includes a call nidaqex.h . My second module is shown below. cedriver.h is simply another header that contains the counter variables and function definitions.
When I attempt to compile both source and the module I get the following errors:
cedrivercomputeoutput.obj .text: undefined reference to '_GPCTR_Control@12'
cedrivercomputeoutput.obj .text: undefined reference to '_NIDAQErrorHandler@12'
cedrivercomputeoutput.obj .text: undefined reference to '_GPCTR_Set_Application@12'
cedrivercomputeoutput.obj .text: undefined reference to '_GPCTR_Change_Parameter@16'
cedrivercomputeoutput.obj .text: undefined reference to '_GPCTR_Watch@16'
It seems as though the functions from the nidaqex header file are not being recognized. Any ideas?
Attached is the module to be compiled with the main source code. I am using the commands xxx main.c cencoderdrivercomputeoutput.c . The main program also just calls the functions at predetermined times.
/ edriver.h
#include "nidaqex.h"
extern u32 GpctrNum_0 = ND_COUNTER_0;
extern u32 GpctrNum_1 = ND_COUNTER_1;
extern i16 iDevice = 1;
extern u32 ulGpctrNum = ND_COUNTER_0;
extern u32 ulCount = 0;
extern i32 ulTCReached = ND_NO;
extern i16 iIgnoreWarning = 0;
//i16 iYieldON = 1;
extern i16 iRetVal = 0;
u32 ReadCounter(void);
void SetupCounter(void);
void DisarmCounter(void);
TIA.
Klaus
(3,615 Views)
(3,603 Views)
I may not be including the file that contains the subroutines for these functions:
GPCTR_Control
NIDAQErrorHandler
GPCTR_Watch
nidaqex includes nidaq.h that contains the function prototypes. What file contains the actual function subroutines?
TIA
Klaus
(3,597 Views)
Found answers to my questions!!!!!
Missing nidaq32.lib and nidex32.lib.
(3,593 Views)
