Measurement Studio for VC++
Problem first time round with DAQmxWriteDigitalLines
Please can any one help with the code below?
(start task)
(create channel)
DAQmxWriteDigitalLines(m_taskHandle, 1, 1, -1#, DAQmx_Val_GroupByChannel, m_writeArray(0), m_sampsPerChanWritten, 0)
(stop task)
m_writeArray is 2 bytes long.
When I first run the task I get a buffer overflow error. When I run it a second time it works fine? The DAQmxGetWriteDigitalLinesBytesPerChan always gives 2 bytes per channel (strange? or expected?) - I tired increasing the m_writeArray size but it size exhibits the same behaviour. Anyone know?
Cheers,
Daniel
(5,317 Views)
Daniel,
You are using the C API for DAQmx. If you are a Measurement Studio for VC++ user, then you may prefer to use the C++ API for DAQmx instead.
Assuming you want to use the C API, I have attached a short program that writes a single sample to a single channel containing a two lines. This program runs fine for me.
-Jeff
(5,299 Views)
Thanks Jeff,
I tried your code in C and it worked as you said. First time around, no problems. I'm calling these functions with VBA (from within Excel,) and for some reason first time round I still get an error. It's curious, and I don't understand it. The problem is runtime error 6, "overflow." Interestingly enough if I step through the code, and pause for a second or so between making the channel and calling the write lines function I don't have a problem. I really dont understand since the C program works well. I've included the class I used to control the lines below, any ideas?
Best Regards,
Daniel
Option Explicit
Private m_sampsPerChanWritten As Long
Private m_TaskHandle As Long
Private m_writeArray(0 To 3) As Byte
Private m_bytesPerWriteDigitalLines As Long
Private Const c_digitalLineHIGH As Long = 1
Private Const c_digitalLineLOW As Long = 0
Private Const c_terminalAddress As String = "Dev1/port0/line0:1"
Private Sub Class_Initialize()
' Create the DAQmx task.
DAQmxErrChk DAQmxCreateTask("", m_TaskHandle)
' Add a digital output channel to the task.
DAQmxErrChk DAQmxCreateDOChan(m_TaskHandle, c_terminalAddress, "", DAQmx_Val_ChanForAllLines)
'Check the number of bytes per channel
DAQmxErrChk DAQmxGetWriteDigitalLinesBytesPerChan(m_TaskHandle, m_bytesPerWriteDigitalLines)
If m_bytesPerWriteDigitalLines <> 2 Then
MsgBox ("Error. Expecting 2 bytes per channel.")
End If
'Verify the task
'DAQmxErrChk DAQmxTaskControl(m_taskHandle, DAQmx_Val_Task_Verify)
'Reserve and Commit the resources for the task
'DAQmxErrChk DAQmxTaskControl(m_taskHandle, DAQmx_Val_Task_Commit)
'Start the task
DAQmxErrChk DAQmxStartTask(m_TaskHandle)
End Sub
Private Sub Class_Terminate()
'stop the task
DAQmxErrChk DAQmxStopTask(m_TaskHandle)
' terminate the task
DAQmxErrChk DAQmxClearTask(m_TaskHandle)
End Sub
Public Sub Inflate()
m_writeArray(0) = c_digitalLineLOW
m_writeArray(1) = c_digitalLineHIGH
'write the array to the digital lines
DAQmxErrChk DAQmxWriteDigitalLines(m_TaskHandle, 1, 1, -1#, DAQmx_Val_GroupByChannel, m_writeArray(0), m_sampsPerChanWritten, 0)
End Sub
Public Sub Deflate()
m_writeArray(0) = c_digitalLineHIGH
m_writeArray(1) = c_digitalLineLOW
End Sub
Public Sub StopAir()
End Sub
(5,289 Views)
Daniel,
Is there any indication of where the overflow occurs ? Does VBA highlight any variable ?
Also what is the exact order in which you call your functions...
I tried
Class_Initialize
Inflate
Deflate
StopAir
Class_Terminate
in VB6.0 (NOT VBA) without error..
What's the order in your app?
Nandan Dharwadker
Staff Software Engineer
Measurement Studio Hardware Team
(5,265 Views)
Nandan,
Thanks for your help. I've tried narrowing down the problem on and off for the last week - it works in VB but not VBA. I'm not convinced there should be a difference between the two, it has to be something I'm doing. Anyway, I gave up (since I'm on a deadline) and wrote an ATL COM Wrapper exposing the functionality I need to Excel. This works perfectly, allowing me to use VBA to automate the object, which suits me perfectly.
Thanks again for your help.
Daniel
(5,236 Views)
