Which example are you talking about?  There is not an example called 4882MFC that ships with Measurement Studio for Visual C++.  Anyway, if you're using the Measurement Studio for Visual C++ libraries, this error would be because you're not linking to Ni4882.lib (Ni4882D.lib for debug, or Ni488270.lib for VC.NET release, or Ni488270D.lib for VC.NET debug).  If you're not using the Measurement Studio for Visual C++ libraries, I think this error would be because you're not linking to Gpib-32.obj.  Please double-check the libraries that you're linking to and see if the appropriate library is missing.
- Elton
