Measurement Studio for VC++
Problems running in CVI a DLL made in Visual c++ 2008
I  have made a DLL in visual c++ 2008.
The function declaration prottypes are defined  as:
#define DLLTYPE void __declspec(dllexport)
#ifdef __cplusplus
extern "C" {
#endif
DLLTYPE RS232OpenPort(const char *Port, int* handle, int *iResult);
#ifdef __cplusplus
#endif
Calling the function in cvi always generates an General Protection Fault at address 6865A1C8.
The dll was tested succesfully in Visual c++ 2008.
Anyone has a solution for that?
(6,685 Views)
Hi Danut81,
If this dll is written using c++ .NET, the problem may be that you are not using our .NET library.  This post has more information on this possibility:
NI forums: CVI call to Managed C++ DLL causes 'General Protection' fault
If you are not using .NET, or this does not resolve your problem, please attach your dll and source so that I can attempt to replicate the issue.
Al B.
Staff Software Engineer - TestStand
CTA/CLD
(6,661 Views)
By reading the post CVI call to Managed C++ DLL causes 'General Protection' fault I indentify the same issue on my DLL.
I was able to get rid of the anoing crash only by removing some calls from a DLL  that was probably using some .NET assemblies (functionality).
Anyway this did not really solved my problem, only I was able to find the root cause. Dynamically loading the library works fine also in my case but this is not what I wanted.
By the way I'm using CVI 8.5
(6,652 Views)
