Measurement Studio for VC++
Problems with PCI-6527 and Callback with DAQ Traditional
Hi all!
I have encountered a serious problem using callback function with traditional NI-DAQ driver when programming in C++. I use the following sentance:
'CMyThread* pThis = (CMyThread*) AfxGetThread( );'.
Unfortunately pThis is null, when callback function is called. Callback function is part of CMyThread class.
Is there a way to assign auxilliary variable to Traditional NI-DAQ? Or is there another way to get pointer to my own thread?
Best regards
(3,257 Views)
Hello kovalenkov,
You mentioned that you are looking for something to assign auxilliary variable to Traditional NI-DAQ. Unfortunately I'm not sure what it is that you are trying to do. What is the purpose of an auxilliary variable and why do you want to use it?
(3,240 Views)
OK. It would be a nice thing to set pointer to your own thread, that callback function should somehow return. Never mind, I managed to get past this little problem with using static variable containing pointer to my thread.
(3,233 Views)
