Measurement Studio for VC++
SOFTWARE HELP
I HAVE INSTALLED AN (PCI-MIO-16XE-10) CARD & I WANT TO DISPLAY TWO ANALOG SIGNAL VOLTAGES TO BE DISPLAYED SIMULTANEOUSLY & THEIR VALUES SHOULD BE CONTINOUSLY UPDATED WITH THE ANALOG SIGNAL ON THE SCREEN.I WANT THAT DATA SHOULD NOT GO TO BUFFER .I AM WRITING THE SOFTWARE IN VC++ & USING WHILE LOOP.
(3,387 Views)
Hello Jivan,
If when you install NI-DAQ, you install Visual C "support", examples should be installed to your hard disk, likely at
"C:\Program Files\National Instruments\NI-DAQ\Examples\VisualC\". There are AI examples that demonstrate
how to input data from your DAQ board and display results to the console. If you have further questions regarding
how to display this data using ComponentWorks++ (Tools for Visual C++) using its User Interface components,
feel free to continue your discussion in this forum. If you have further data acquisition related questions, then the
proper forum for them is Multifunction IO at the following link:
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=8&RFORMNUMBER=2&RHIDETAG=TRUE&UCATEGORY_0=_30&UCATEGORY_S=0
Jerem
iah Cox
http://www.ni.com/ask
(3,387 Views)
