Measurement Studio for VC++
ScatterGraph InteractionModeDefault Cursor Bug
     I use Measurement Studio 8.6.1 and when I set the InteractionModeDefault of a ScatterGraph via a ContextMenu the mouse cursor is not updated until it moves outside the ScatterGraph.
See code attached.
Thanks for your help.
Guillaume
(5,996 Views)
Hi Belly,
This behavior has been reported to R&D as Corrective Action Request #217352.  As a workaround, you can manually update the cursor using the following code:
Cursor = NationalInstruments.UI.MouseCursors.ZoomXY;
 note that you will need to set the cursor back to the default when themouse leaves the graph, which can be done pretty easily:
private void scatterGraph1_MouseLeave(object sender, EventArgs e) { Cursor = Cursors.Arrow; }
Al B.
Staff Software Engineer - TestStand
CTA/CLD
(5,974 Views)
