Measurement Studio for VC++
Searching for a C/C++ program for 6503 ...
I'm searching for a basic C/C++ program to light LED with digital signal.
The program present as exemples in the CD seems not to work with my card.
Thanks by advance.
Nrv 🙂
(3,263 Views)
Hello;
The examples DIoneLine and DIonePort at C:\Program Files\National Instruments\NI-DAQ\exmaples\Visual C\DI\ should work with your hardware. You are probably using the other ones that implement handshaking and pattern I/O, and aren't support by your board.
That board of yours only supports static operations.
Hope this helps.
Filipe A.
(3,263 Views)
I thought DIonePort was a program for reading an imput ?!
Anyway, I've been trying DIonePort (wich doesn't work), DIoneLine & DOoneLine ("DO" for "Digital Outpout" isn't it ?), because I just want to light one LED, and no one is running with my card : I always got an "10613 error", it is to say "my device do not understand the command, whereas the driver do".
How can I do, wich fonction to use for a derect command of one line, on one port ?
I need help ...
Nrv 🙂
(3,263 Views)
