Measurement Studio for VC++
Setting Chart History
Is there a way where I can set the chart history to a user defined value while my program is running? Example, when the program starts running, the graph history is set to 200, so the max range for the x-axis is 200, once it gets to 200 the window will start shifting. I want the user to have control over this property. If the user wants the chart history to be 500, then I want to be able to set that property of the graph to 500 through my program. How would I be able to do this?
(3,117 Views)
I'm not sure what you're looking for. The graph has a ChartLength property that will allow you to specify how many points the graph stores while charting. If you would like to make this customizable in your application, you could provide a way to do this in the interface of your application. For example, you could create a dialog that has a text box or a numeric edit, then bring this dialog up from a menu and set the ChartLength property according to what they enter in the dialog. Is there something else that you were looking for from the graph for this?
- Elton
(3,117 Views)
