Measurement Studio for VC++
Setting an image pointer to CNiGraph control
I'm programming C++ with Visual Studio 6.0 on Win 2000.
I am actually displaying a bitmap in a Component Work++ CNiGraph control so I can view a peek detection plot over the image.
The only possibility I see to display an image on the background of the plot area is to set the URL to a file which was previously saved on disk. The problem is that saving and reloading the image is very slow.
Is there a way to display my image on the plot area of my CNiGraph control by directly setting a char pointer to the control?
Best regards.
Fred.
(3,268 Views)
Hello
The control image is returned as an enhanced metafile in Measurement Studio 6.0. You can copy that image to a clipboard and then use it whenever you need. Check out this link for how to do this.
A meta file is not an simple as a bitmap though, see here for format. So getting a char * handle to it might not be the best thing to do.
Hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(3,268 Views)
