Measurement Studio for VC++
Settling time for DAQ
What is the best way to increase settling time on Visual C++ measurements of the PXI-6255 A to D? We needed to make some hardware changes that resulted in a measurement via a high-resistance voltage divider (24.7k and 100k) with secondary measurements on a near-ground voltage. The switching between the two sources leads to ghosting/crosstalk effects. We do not have a way to make hardware changes at the moment. Decreasing sampling frequency only helps to a certain point, after which the voltage reading is still low.
I attempted to use the function daqmxsetswitchdevsettlingtime but have been unable to find documentation regarding the first parameter, char deviceName[]. What is the Device Name?
If this function is depreciated, is there a replacement function?
(6,199 Views)
Hey GoodSirEric,
Are you using an NI switch?
http://zone.ni.com/reference/en-XX/help/375472G-01/switch/extra_settling_time/
(6,161 Views)
Hello TwinTwo!
No, I am using an Analog to Digital card (PXI-6255) and creating a session with DAQmxCreateTask("",&taskHandleAtoD);
niSwitch_SetAttributeViReal64() is not recognized as a valid function because I have not included the necessary switch header files. Do the switch functions accept a task handle created with DAQmxCreateTask(), and can they apply settings to Analog to Digital cards?
(6,154 Views)
Accepted by topic author GoodSirEric
NI Switch functions only apply for NI Switch hardware. What you want is to change the convert clock to alter the inter-channel delay.
http://digital.ni.com/public.nsf/websearch/65E7445DB1AA5DC586256A410058697B?OpenDocument
(6,141 Views)
Dennis is right! In that link you can find how to allow additional settling time, this other links might be helpful for you to understand a little more:
http://digital.ni.com/public.nsf/allkb/42484E84DA98053686256D32006E0494
http://zone.ni.com/reference/en-XX/help/370471W-01/mxcprop/func1848/
http://zone.ni.com/reference/en-XX/help/370471W-01/mxcprop/attr1848/
https://decibel.ni.com/content/docs/DOC-14548
(6,133 Views)
Thanks! Those resources were extremely helpful!
(6,127 Views)
