Measurement Studio for VC++
Specifying Channel Read order Ni-DAQmx.
Hi, I am currently upgrading C code from Ni-DAQ legacy to the Ni-DAQmx format and was wondering if it is possible to specify a channel read order? ie. reading channels 1,7,2,7,3,7,4,7,5,7,6,7 in that specific order? Any help is appreciated
(3,024 Views)
Hi Luca, check the DAQmx ANSI C examples that comes with the driver install. They are located in:
C:\Users\Public\Documents\National Instruments\NI-DAQ\Examples\DAQmx ANSI C
Hope this is helpful.
(2,988 Views)
I have, but i cannot seem to find an example that helps me out in solving my problem
(2,985 Views)
i don't think there is a specific one with sequencial adquisition. you will need play a little bit with what is there. The is additional information about how the functions works on the LabWindows help window.
(2,976 Views)
