Measurement Studio for VC++
Start task on trigger
I'm developping a c++ project using DAQmx. I use the NI PCI 6534 card and trying to start a digital output task when i get a bit from /dev1/port2/line0. So i suppose i have to use a trigger but i m not sure about how to use trigger functions.
Someone could help me on their use?
Thank you.
Here is what i tried to do but doesn t work (Error terminal for this device invalid ) :
int daqmxSendData(uInt8 data[], int size){
int error=0;
TaskHandle taskHandle=0;
char errBuff[2048]={'\0'};
// DAQmx Configure Code
DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
DAQmxErrChk (DAQmxCreateDOChan(taskHandle,"Dev1/line0:15","",DAQmx_Val_ChanForAllLines));
DAQmxErrChk (DAQmxCfgBurstHandshakingTimingExportClock(taskHandle,DAQmx_Val_ContSamps,size,1000.0,"/Dev1/PFI4",DAQmx_Val_ActiveHigh,DAQmx_Val_High,DAQmx_Val_ActiveLow));
DAQmxErrChk (DAQmxSetPauseTrigType(taskHandle,DAQmx_Val_DigLvl));
DAQmxErrChk (DAQmxSetDigLvlPauseTrigSrc(taskHandle,"/Dev1/port2/line0"));
DAQmxErrChk (DAQmxSetDigLvlPauseTrigWhen(taskHandle,DAQmx_Val_High));
DAQmxErrChk (DAQmxSetWriteRegenMode(taskHandle,DAQmx_Val_AllowRegen));
DAQmxErrChk (DAQmxRegisterDoneEvent(taskHandle,0,DoneCallback,NULL));
DAQmxErrChk (DAQmxWriteDigitalLines(taskHandle,size,0,10.0,DAQmx_Val_GroupByChannel,data,NULL,NULL));
// DAQmx Start Code
DAQmxErrChk (DAQmxStartTask(taskHandle));
printf("Generating digital output continuously. Press Enter to interrupt\n");
getchar();
Error:
if( DAQmxFailed(error) )
DAQmxGetExtendedErrorInfo(errBuff,2048);
if( taskHandle!=0 ) {
// DAQmx Stop Code
DAQmxStopTask(taskHandle);
DAQmxClearTask(taskHandle);
printf("DAQmx Error: %s\n",errBuff);
return 0;
(6,301 Views)
If you have a look on the function help, you will find out your answer.
Actually, I think you should use this fonction :
"Configures the task to start acquiring or generating samples on a rising or falling edge of a digital signal.
Prototype
int32 DAQmxCfgDigEdgeStartTrig (TaskHandle Task_Handle, char Trigger_Source[], int32 Trigger_Edge);"
These information comes from the help document!
Celine
National Instruments France
(6,288 Views)
Ok Thank you for your reply.
So i tried to use your function. But i get an error while using it.
triggerDAQmx Error: Start Trigger Type requested is not supported given the requested Timing Type.
To use the requested Timing Type, do not set the Start Trigger Type property. NI-DAQmx automatically selects a compatible Start Trigger Type setting.
To use the requested Start Trigger Type, select a different Timing Type.
Property: DAQmx_SampTimingType
Requested Value: DAQmx_Val_BurstHandshake
Property: DAQmx_StartTrig_Type
Requested Value: DAQmx_Val_DigEdge
Task Name: _unnamedTask<0>
Status Code: -200904
Apparently i can't use :
DAQmxCfgDigEdgeStartTrig (taskHandle, "/Dev1/line0" , DAQmx_Val_Rising);
with :
DAQmxCfgBurstHandshakingTimingExportClock(taskHandle,DAQmx_Val_ContSamps,size,1000.0,"/Dev1/PFI4",DAQmx_Val_ActiveHigh,DAQmx_Val_High,DAQmx_Val_ActiveHigh)
I've changed my code and replace DAQmxCfgBurstHandshakingTimingExportClock with DAQmxCfgSampClkTiming(taskHandle,"/Dev1/PFI2",1000.0,DAQmx_Val_Rising,DAQmx_Val_ContSamps,size));
and now i can use  DAQmxCfgDigEdgeStartTrig (taskHandle, "/Dev1/line0" , DAQmx_Val_Rising); but still got an error with the line i want to use for the trigger.
triggerDAQmx Error: Terminal for the device is invalid.
Property: DAQmx_DigEdge_StartTrig_Src
Requested Value: /Dev1/line0
Status Code: -89129
Any idea?
Thank you.
Alex.
(6,282 Views)
I'm still stuck with this function.
I think that I understood that a trigger can t be configure on a Digital output line like i did above. But my function have to generate data on lines 0:15 and be able to read on line 16:31 to get trigger info.
So i found that we can tristate line to be able to change input/output lines and so now, I m trying to use a pattern trigger on line 16:31 but I still can't make it works.
Thank you for any help.
Alex.
my code:
int daqmxSendData(uInt8 data[], int size, int mode){
int error=0;
int32 read,bytesPerSamp;
DAQmxErrChk (DAQmxCreateDOChan(taskHandle,"Dev1/line0:31","",DAQmx_Val_ChanForAllLines));
DAQmxErrChk (DAQmxCfgSampClkTiming(taskHandle,"",1000.0,DAQmx_Val_Rising,DAQmx_Val_ContSamps,size));
if(mode == 1){
printf("trigger");
DAQmxErrChk ( DAQmxSetDOTristate(taskHandle,"/Dev1/line16:31",1));
DAQmxErrChk (DAQmxCfgDigPatternStartTrig (taskHandle, "/Dev1/line16:31","1000000000000000" , DAQmx_Val_PatternMatches));
// DAQmx Start Code
getchar();
Error:
// DAQmx Stop Code
return 0;
(6,260 Views)
