Measurement Studio for VC++
Stop slider from jumping
I would like to stop the pointer of a CNiSlider from jumping to the cursor when I click on the slider.
Is there a property I can set for this like m_SliderCtrl.SetPageSize( 0 );
for the MFC CSliderCtrl class?
Do I have to go in and overide mouse events?
matthew
(3,246 Views)
Hello
If you want to prevent the slider pointer from jumping on a mouse click, but you still want the user to be able to drag the slier around, you should change the mode of the pointer to PointerModeControlSmooth. If you are using CNi objects (instead of the class wizard wrappers), you would do the following:
m_slidetest.Pointers.Item(1).SetMode(CNiPointer::PointerModes(5))
Check out the help for CWPointer for more details on the various modes and what they mean.
Bilal Durrani
NI
Bilal Durrani
NI
(3,246 Views)
Thanks, perfect
(3,246 Views)
