Measurement Studio for VC++
Synchronizing Analog and Digital Output
I am having trouble synchronizing the analog and digital output on my card. I have successfully been able to program the card to simply display the analog output. My trouble comes when I try to add the digital task. I realize that I need to create two separate tasks for each type of output, but how exactly can I sync them to run in parallel with eachother. The DAQmxCfgSampClkTiming function requires certain fixed frequencies like 100Mhz/80Mhz/20Mhz or 100kHz. How can I go about programming so that I can output both the digital and analog signals at any frequency.
Thanks so much
(6,606 Views)
Hey Sunil,
Unfortunately this is not a C++ forum so I can't help you with the programming in that respect, however I have written some LV code to show how we call our functions and perhaps this can help with the writing of your code. See code attached.
Regards
Andrew George @ NI UK
(6,549 Views)
Synchronizing Analog Input and Analog Output Using RTSI Hardware
You can synchronize National Instruments devices using the Real-Time System Integration (RTSI) bus. The RTSI bus connects data acquisition boards directly, with no external wiring, allowing you to accurately synchronize the subsystems of a device. It can also synchronize multiple subsystems on multiple devices using a cable. You can eliminate latency in synchronous acquisitions by coordinating the devices using the RTSI bus.
You can configure the system so that the start of the acquisition will trigger the start of the generation of data in the hardware. For example, you can configure the analog input object as the system controlling the start of the analog output object.
The default TriggerType is Immediate and this allows the analog input object to start when the start command is executed. Set the ExternalTriggerDriveLine property to signal on the RTSI bus, which triggers the analog output object.
ai = analoginput('nidaq', 'Dev1');
addchannel(ai, 0);
ai.ExternalTriggerDriveLine = 'RTSI0';
ao = analogoutput('nidaq', 'Dev1');
addchannel(ao, 0);
Next, you should set the analog output object to receive a trigger from the same RTSI line you specified for the analog input object's ExternalTriggerDriveLine. You should also set the TriggerType to HwDigital. To make sure that both the analog input object and the analog output object start simultaneously, you should also set the analog output object'sTriggerCondition to PositiveEdge.
ao.TriggerType = 'HwDigital';
ao.HwDigitalTriggerSource = 'RTSI0';
ao.TriggerCondition = 'PositiveEdge';
You should start your analog output object first, and then the analog input object. The analog output object starts, but will not send data until the analog input object starts.
putdata(ao, zeros(1000,1));
start(ao);
start(ai);
When the analog input object is started, it will send a pulse on the RTSI bus. The analog output object detects this pulse and starts almost simultaneously.
For more information on starting analog input objects and analog output objects simultaneously, refer to the Data Acquisition Toolbox demo, Synchronizing Analog Input and Output Using RTSI.
_______________________________________________________________________
Want to get-on Google's first page and loads of traffic to our website? Hire a SEO Specialist from Ocean Groups[url=http://oceangroups.org/] seo pecialist [/url]
(6,508 Views)
