Measurement Studio for VC++
Syntax for configuring a CWDIO object in C++.
I'm using the PCI-6032E board (device 1), which has a single DIO port (port 0). I would like to make line 0 an output and the remaining seven lines inputs. I dynamically create a CWDIO object to write to line 0. What would the C++ syntax look like for configuring the CWDIO object and writing to line 0?
(3,321 Views)
There several CWDIO examples written in VC++ at the following ftp site:
ftp://ftp.ni.com/support/compworks/samples/
Look for the zip file CW3VC.zip
You'll be able to see the syntax you're looking for in the in the examples under the DAQ/DIO and DAQ/ReadWrite folders. Just note that these were written with CW 3.0.
Azucena
(3,321 Views)
I don't see the example showing syntax for a dynamically created CWDIO control. All the examples I see are using the property pages from the Dialog itself.
Grant
Grant M. Johnson
Project Engineer
LECO Corporation
(3,321 Views)
