Measurement Studio for VC++
System clock slow
sir with due respect :
I run my application at 6:18PM 28 May Satureday 2005 at that time the sytem time was correct.I remain the application running on my pc.Today I check the syatem time it is one hour late(back)than the original time.Now the the time is 8:18 30 May Monday 2005 But my sytem time is 7:16 30 May 2005.Please tell why it is so.
ajmal thanks
Lead Data Scientist
(3,553 Views)
Hello Ajmal,
This may not be a problem related to the Measurement Studio components of your application. I have a few questions that should clarify for me what is happening.
1. Does the system time reported by your application match the clock on your computer?
2. Which Measurement Studio controls play a role in getting the system time?
3. What version of Measurement Studio are you using? On which Operating System?
Eric M
(3,540 Views)
sir
1)when i run my application then the system clock becomes slow ;
i obeserved this problem by comparing the system clock time with my wrest watch and stop watch.I found that the system clocks is slower than the stop watch time.The oerating system i m using is WINDOW2000 and XP
2)Second i using no control,I m using daq low level data acquisition API's
3)I m developing my Application in VC++6.0 i donot know about measurement studio
thanks a lot
Lead Data Scientist
(3,514 Views)
I recommend you review the KnowledgeBase document:
My Data Acquisition (DAQ) Board Is Slowing Down My System Clock.
This document has suggestions for resolving the behavior you have described.
Eric M
(3,496 Views)
