Measurement Studio for VC++
TDMS file opener with matlab
I'm trying to open the TDMS file with the source code from TDMS Reader - File Exchange - MATLAB Central (mathworks.com).
I was able to open some files but weren't able to open files saved using DAQmx assist block.
The error I'm getting is as in the picture below.
The code I use is
routeV = 'I:\Temp';
A = 1;
B = 4;
for a = 1:A
[P,~] = TDMS_readTDMSFile([routeV,'_',num2str(a.','%04d'),'.tdms']);
% for b = 1:B
% DB(:,a,b) = P.data{1,b+2}';
% end
end
and the files I'm trying to open are in the attached file.
Thank you in advance.
Message 1 of 1
(1,657 Views)
