Measurement Studio for VC++
The extended (complete) header file of nidaq32.dll?
Does someone have the extended (complete) header file of nidaq32.dll? About 30% of the functions, many used by lvdaq.dll, are not documented.
(2,936 Views)
Hello
lvdaq.dll is meant to be used only thru LabVIEW. The functions not present in the header are internal only and hence are not documented. You really should not be using those functions anyways, since they be changed in a different release of ni-daq with out any notice, and your code could break.
Bilal Durrani
NI
Bilal Durrani
NI
(2,936 Views)
