Measurement Studio for VC++
Transmit/Receive Manchester signals using digital output of PCI 6224
How can a manchester signal be transmitted and received using the DIO of the pci 6224 board?
I want to create a NRZ manchester signal on a digital ouput channel and then have the ability to receive and interpret the same type of signal on a digital input channel.
Any assistance would be greatly appreciated.
(7,080 Views)
Accepted by topic author VJohnson
Hi VJohnson,
You might find this discussion forum post useful.
Looks like LabVIEW does not have Manchester coding/decoding built in, but it should be do able in your VI by replacing every element with the corresponding two elements, and using double the baud rate as your clock rate.
Scott M.
(7,072 Views)
