Measurement Studio for VC++
Triggering at changes of waveform with NI-DAQ 1200?
I am trying to trigger my acquisition whenever a sine wave starts, and after an acquisition , whenever it finishes. My code up till now is as follows but I cannot getr it to work. Can anyone give me any suggestions or help? I would be eternally thankful.
void sVoltage( char *Voltage, double Buffer[1000], int ulCount)
FILE *fptr;
char *extension = ".dat";
int i=0;
while(kbhit()); // "eat" any char already in keyboard buffer
strcat(Voltage, extension);
if ( (fptr = fopen(Voltage,"wb")) == NULL)
printf("Cannot open %s \n\n", Voltage);
else
// write buffer to file
for (i=0; i {
fprintf(fptr, "%f\n", Buffer[i]);
fclose(fptr); // close file
///////// THE MAIN /////////
void main(void)
// Local Variable Declarations for Analog Input:
i16 iStatus = 0;
i16 iRetVal = 0;
i16 iDevice = 1;
f64 Trigg = 0.1;
u32 PtrTrigger = 1;
f64 dVoltage_A[BuffSize];
f64 dVoltage_B[BuffSize];
f64 dVoltage_C[BuffSize];
f64 dTempVoltage = 0.0;
f64 *ptr;
char szFileVoltage[256];
i16 iChanInput_A = 2;
i16 iChanInput_B = 2;
i16 iChanInput_C = 0;
i16 iGainInput = 1;
i16 iChan1 = 0;
i16 iChan2 = 0;
i16 iChan3 = 0;
i16 iGain = 1;
i16 iFinalScanOrder[3] = {0,1,2};
f64 dSampRate = 25600.0;
f64 dScanRate = 0.0;
u32 ulCount = 20;
f64 dGainAdjust = 1.0;
f64 dOffset = 0.0;
i16 iUnits = 0;
i16 iSampTB = 0;
u16 uSampInt = 0;
i16 iScanTB = 0;
u16 uScanInt = 0;
static i16 piBuffer[1000] = {0};
static f64 pdVoltBuffer[1000] = {0.0};
i16 iDAQstopped = 0;
u32 ulRetrieved = 0;
i16 iNumMUXBrds = 0;
i16 iNumChans = 3;
static i16 piChanVect[3] = {0, 1, 2};
static i16 piGainVect[3] = {1, 1, 1};
i16 iIgnoreWarning = 0;
u32 i =0;
char tmpbuf[128];
// Capture settings, initialise all user-specified variables
printf("Input name of file, with path, to which you want to save the current data: ");
scanf("%s\n", szFileVoltage);
printf("Enter the Voltage Threshold for the data acquisition trigger: ");
scanf("%d\n", Trigg);
// printf("Enter the time interval for which data acquisition is to take place: ");
// scanf("%d\n", Interval);
// Pointer is 1 when closing, -1 to open, or at least what I understand by them
// while( PtrTrigger > 0 )
// iStatus = AI_VRead(iDevice, iChanInput_A, iGainInput, &dVoltage_A[i]);
// iRetVal = NIDAQErrorHandler(iStatus, "AI_VRead", iIgnoreWarning);
// printf("The Voltage at AI channel %d is %lf volts. \n", iChanInput_A, dVoltage_A[i]);
// ptr = &dVoltage_A[i];
// if (*ptr >= Trigg)
// //TRIGGER HERE
// iStatus = Lab_ISCAN_Op(iDevice, iNumChans, iGain, piBuffer,
// ulCount, dSampRate, dScanRate, iFinalScanOrder);
// iRetVal = NIDAQErrorHandler(iStatus, "Lab_ISCAN_Op", iIgnoreWarning);
// iStatus = SCAN_Demux(piBuffer, ulCount, iNumChans, iNumMUXBrds);
// iRetVal = NIDAQErrorHandler(iStatus, "SCAN_Demux", iIgnoreWarning);
// iStatus = DAQ_VScale(iDevice, iChan1, iGain, dGainAdjust, dOffset,
// ulCount, piBuffer, pdVoltBuffer);
// iRetVal = NIDAQErrorHandler(iStatus, "DAQ_VScale", iIgnoreWarning);
//// //SAVE
// Set time zone from ZT environment variable. If TZ is not set
// the operating system is queried to obtain the default value
// for the variable
// _tzset();
//Acquire operating system-style time
// _strtime(tmpbuf);
// // Get rid of colon
// tmpbuf[2]=tmpbuf[3];
// tmpbuf[3]=tmpbuf[4];
// tmpbuf[5]=tmpbuf[7];
// tmpbuf[6]=tmpbuf[8];
// tmpbuf[9]='\0';
// Concatenate the strings
// strcat(tmpbuf, szFileVoltage);
// sVoltage(tmpbuf, pdVoltBuffer, ulCount);
// Check for buffer boundry value
// if (strlen(szFileVoltage) >= 256)
// break;
// PtrTrigger = -1;
// else if (*ptr < Trigg)
// if (i =! BuffSize)
// i = i++;
// else if (i > BuffSize)
// i = 0;
// while( PtrTrigger < 0 )
// if ((*ptr == 0) && (dVoltage_A[(i-1)] == 0))
// //TRIGGER HERE
// //SAVE
// // Set time zone from ZT environment variable. If TZ is not set
// // the operating system is queried to obtain the default value
// // for the variable
// _tzset();
// //Acquire operating system-style time
// tmpbuf[9]='\0';
// // Check for buffer boundry value
// break;
// PtrTrigger = 1;
// else
// i = i++;
// i = 0;
(5,042 Views)
Hy you use a lot. Maybe it's better to work with ActiveX components. Make your code much easier
Regards
(5,042 Views)
Probably, but at this moment I have to program this fast and Active X needs time to program the individua l components unless you buy a Labview or something similar. In addition I do not know how to program the individual compoenets and objects. Can you give me any help on how to do this with straight C?
(5,042 Views)
Normally when you use activex, you can do everything int the component and to start you have to do the following:
configure
start
and to stop:
stop
Regards
Stefan
(5,042 Views)
... and how do I setup the object. Do you have a very small example that could show me and lead me the way?
Thank you.
(5,042 Views)
Here are a few examples
Regards
Stefan
(5,042 Views)
Thank you. But you still need componentworks to run the programs. I do not have any measurement studio, I just have visual C++.
Iliana
(5,042 Views)
