Measurement Studio for VC++
Triggers no longer firing after upgrade from MXI3 to MXI4
I am a little puzzled and hoping someone can offer me some advice on troubleshooting.
We have setup including several 5112 cards and a 6608 timing card. Software has been using in production for years. We are currently using MXI3s to connect to the PXI but we are running low on spares. I am trying to replace the MXI3 with a MXI4 but running into some issues. For some reason with the MXI4 the niScope_Read() function is returning error code -10800 when the software runs. The problem is if I replace with a MXI3 the same equipment works properly and I get signals. It appears as if the trigger events are not occuring.
Can anyone give me some pointers to troubleshoot this? I am pretty sure my software configuration is correct.
NI-DAQ 6.9.3 (Are the newer versions of legacy NI-Daq backwards compatible with this?)
NI-Scope 2.1.4
IVI Compliance 3.2
Measurement Studio 6.0
MAX 4.5
NI-PAL 2.3
NI-SPY 2.6.0
Most of this software came on the PXI Platform services disc. Any suggestions would be appreciated.
Message 1 of 1
(5,670 Views)
