Measurement Studio for VC++
Turn off evalutation version
I am performing maintenance on existing software that uses version 3.0.1 of the Measurment Studio OCX controls. When I installed the release version of the product, the controls appeared to work fine. When I started working with them in the development environment, they started showing that I was using the evalation version. How do I turn off the evaluation notification?
(3,590 Views)
Take a look at the Knowledge Base article ActiveX Controls Evaluation Message Box Appears after Installing Measurement Studio and see if the Measurement Studio License Fixer Utility helps resolve this issue.
- Elton
(3,590 Views)
Thank you. However, the license fixer is for either version 6 or version 7, not for version 3.
(3,590 Views)
You can try by uninstalling Measurement Studio 3 and ensuring that the you delete the activex cotnrols from your machine. You can do this by unregistering the cwui.ocx controls ( using regsvr32 \u on the cwui.ocx) and then delete the file. This cleans out all the references to that control from the registry. Delete the control only after it has been unregistered. Then reboot, and try installing Measurement Studio again.
Hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(3,590 Views)
Measurement Studio 1.0 ships with the 3.0 versions of the ActiveX controls. The Measurement Studio License Fixer Utility works with Measurement Studio versions 1.0, 6.0 and 7.0. Try the utility and see if it fixes the issue.
Nauman
(3,590 Views)
