Measurement Studio for VC++
USE IVI-DMM CLASS Drivers IN VC6.0
The problems with using IVI and VC6.0
Questions Described
IN VC6.0there is a fatal, unknown link error when I call IVI CLASS DRIVERS to driver NI pxi4070. How can I solve it?
I have other questions about using IVI:
(1)    I can run IVI examples in the LabView or LabWindows/CVI, but why I can’t call IVI-Class Drivers in the VC 6.0? In my opinion, it may be a parameters-transfer problem. I don’t know how the configuration parameters in the NI MAX transferred to the  LabView or LabWindows/CVI? Is it automatic? How can I transfer the configuration parameters in the NI MAX to VC6.0?
(2)    In addition, Measurement Studio includes the IVI activeX?
(3)    Moreover, Can you show me an example that how to use IVI-Class Drivers to control pxi4070 in the VC6.0?
(4)    At last, how can I use VIs in the VC6.0?
Thanks a lot
(5,741 Views)
Have you tried the Getting Started guide at http://ivifoundation.org/
(5,737 Views)
Thanks for your reply.
I have looked up these materails on www.ivifoundation.org, But it doesn't work,
Could you give me other suggestions?
Thanks a lot!
(5,734 Views)
