Measurement Studio for VC++
Unresolved Link
I am trying to detect edges on an image.
Everything looks fine except the actual imaqFindEdge function.
StraightEdgeReport *report1, *report2, *report3, *report4;
RotatedRect rect1 = { 90, 81 ,80, 77, 0.00};
RotatedRect rect2 = {188, 79, 80, 80, 0.00};
RotatedRect rect3 = { 94, 250, 70, 80, 0.00};
RotatedRect rect4 = {138, 250, 70, 80, 0.00};
BestLine *line1, *line2, *line3, *line4;
PointFloat pointFloat12, pointFloat34;
Point point12, point34;
report1 = imaqFindEdge(m_LowerCameraProcessedImage, rect1, IMAQ_TOP_TO_BOTTOM, NULL, NULL);
I was sure to include the
#include "nimachinevision.h"
statement
I am getting the following error when I try to execute it (It does compile with no errors)
error LNK2001: unresolved external symbol "struct StraightEdgeReport_struct * __stdcall imaqFindEdge
I know I am probably missing something simple, but can not think of what it is.
Any help you can provide will be greatly appreciated."
-posted by oso on 10/17/2002
Brent R on 10/18/2002 answered:
"You will need to include the \Vision\Lib\MSVC\nivision.lib file in the project. Go to Project >> Settings... and select the Link tab. Add this file to the project.
Brent R.
National Instruments"
Brent,
I have tried this, but no success. If I look through niVision.lib with a hex editor, I notice that "imaqFindEdge" is not there. Could you verify this for me. If so, what would you recommend next?
Enclosed is the code I am trying to compile. This is basically a blank dialog project with just a push button on the form.
(3,644 Views)
Sir,
Most likely you don't have the linking directories set correctly. Go to Tools>>options>>directories and add all the directories for the include files and lib files. This should get your program linking up.
Best Regards,
Michael Hallonan
(3,644 Views)
Thanks for the reply Michael.
I verified this and it looks like my project is set up properly.
I am still getting the linking error.
Compiles are fine, no errors.
Do you have any further suggestions?
Thanks again,
Chuck
(3,644 Views)
IMAQ Vision for LabWindows/CVI is a ANSI C library (.lib), but National Instruments Machine Vision is a separate, open-source product, so source for those functions aren't in the IMAQ Vision library. You can build machine vision into a library if you wish and use that in your projects, or can just add file source/machinevision.c to your project and build it along with your other source files. This should resolve the linker error you're getting.
-- Chris
(3,644 Views)
