Measurement Studio for VC++
Use 80mhzTimetable for counting and how can i set a trigger level for a counter
Hello
i work with this example and a ni USB 6152.
#include <stdio.h>
#include <NIDAQmx.h>
#define DAQmxErrChk(functionCall) if( DAQmxFailed(error=(functionCall)) ) goto Error; else
int main(void)
	int         error=0;
	int			i=0;
	TaskHandle  taskHandle=0;
	int32       read;
	uInt32      data[1000000];
	char        errBuff[2048]={'\0'};
	// DAQmx Configure Code
	DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
	DAQmxErrChk (DAQmxCreateCICountEdgesChan(taskHandle,"Dev1/ctr0","",DAQmx_Val_Rising,0,DAQmx_Val_CountUp));
	DAQmxErrChk (DAQmxCfgSampClkTiming(taskHandle,"/Dev1/80MHzTimebase",80000000.0,DAQmx_Val_Rising,DAQmx_Val_ContSamps,1000000));
	// DAQmx Start Code
	DAQmxErrChk (DAQmxStartTask(taskHandle));
	printf("Continuously reading. Press Ctrl+C to interrupt\n");
	while( 1 ) {
		// DAQmx Read Code
		DAQmxErrChk (DAQmxReadCounterU32(taskHandle,1000000,10.0,data,1000000,&read,NULL));
		printf("\rAcquired %d samples\n",read);
		for(i=0;i<1000000; i++)
			printf("%d\r\n", data[i]);
		fflush(stdout);
Error:
	puts("");
	if( DAQmxFailed(error) )
		DAQmxGetExtendedErrorInfo(errBuff,2048);
	if( taskHandle!=0 ) {
		// DAQmx Stop Code
		DAQmxStopTask(taskHandle);
		DAQmxClearTask(taskHandle);
		printf("DAQmx Error: %s\n",errBuff);
	printf("End of program, press Enter key to quit\n");
	getchar();
	return 0;
 But how can i work with the 80Mhz Timebase and set the trigger point to 0Volt?? I measure that the triggerpint is round 1,7 Volt.
I have a sinus signal who is varius between 0hz and 6khz. And need exact cointing and the default 100khz Timetabel ist not exact enouh. With my 1MHZ test signalhe doesn't count all .
How can i route the 80Mhz timetable to the counter as external clock for solving my problem..
Thanks for helping me.
(7,452 Views)
there is a function called vielen "DAQmxSetCICtrTimebaseSrc" which should do what you want. You can find it in the reference help on the following link:
http://zone.ni.com/reference/en-XX/help/370471W-01/mxcprop/attr0143/
Do you really have an USB-6152? I was looking after it on ni.com, but could not find the device anywhere...
Have a nice day,
Janina
(7,401 Views)
Sorry I have a 6259.
i will try to use "DAQmxSetCICtrTimebaseSrc".
thank you.
(7,398 Views)
