Measurement Studio for VC++
Using CNiMath::LeastSquaresFit()
Could you please take a look at the project I've posted which is trying to use the LeastSquaresFit() using the data provided in the help file? When I compile I always get the following message:
Math Exception : Input Matrix is Singular. The system of equations cannot be solved.
Thanks in advance,
Grant
Grant M. Johnson
Project Engineer
LECO Corporation
(4,019 Views)
Hello
This was actaully a reported issue. We are working to correct this in the future release of Measurement Studio. The way around this is to initialize the stdDev vector with a non-zero value. This will not affect the outcome of the LeastSquareFit function.
I hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(4,019 Views)
Thanks. I set the stdDev vector to all 1's and it works great.
Grant
Grant M. Johnson
Project Engineer
LECO Corporation
(4,019 Views)
