Measurement Studio for VC++
Using a Counter(PC-TIO-10) to Perform Quadrature Encoder Buffered Position Measurement in Visual C++
I have Driver Ni-Daq 6.9 and Using a Counter to Perform Quadrature Encoder Buffered Position Measurement in Visual C++ 6.0
(I think Ni-Daq not support PC-TIO-10 because card not support pulg&play, you can hint me driver for support this card. ) and i want example program for read counter. i use Visual C++ for run,i don't use Measurement Studio.
(3,426 Views)
You should post this question in the Counter/Timer section of Developer's Exchange here. This forum is used and monitored by Measurement Studio users and you will get better results asking this to the Counter/Timing users in that forum.
Best Regards,
Chris Matthews
(3,426 Views)
NI-DAQ 6.9 supports the PC-TIO-10.
I attached an example that will show you how to do it in CVI (ANSI C).
(3,426 Views)
