Measurement Studio for VC++
VS 6 SP 3 needed for MS 1.0
I'm trying to re-create a toolset for an old project that we need to update.
I have Visual Studio 6.0 SP6 installed, yet when I install Measurement Studio 1.0, it does a popup saying it needs VS 6.0 SP3.
Does MS 1.0 truly require VS6.0 SP3, or is it just not recognizing that VS 6.0 SP6 is a later release of VS?
Thanks for any insight into this.
Menchar
(7,549 Views)
I am using a WinXp system, maye that's the problem?
Interestingly enough, I can install ComponentWorks (VB activeX support) without the same error being generated.
Menchar
(7,539 Views)
Accepted by topic author menchar
This is caused by a mistake we made in the Measurement Studio 1.0 installer. The product itself requires SP3 or later, but the installer keys off of a registry value that is created only by the SP3 installer (and not by later SP installers).
You can add a registry value to trick the installer into thinking sp3 is installed on the machine.
Create a string value named "sp3" (no quotes) under the key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\VisualStudio\6.0\ServicePacks.
Here's a link to an old thread on this topic:
http://forums.ni.com/ni/board/message?board.id=231&message.id=1347&requireLogin=False
We now generally follow a policy of "Warm but allow" instead of "Inform and prevent" to avoid issues like this.
David Rohacek
(7,517 Views)
Thanks - I didn't find that old thread before.
I added the sp3 stringf value and now the MS 1.0 installs all OK on my VS SP6 system.
The thread mentions using eval version of Visual Sutdio 6.0, but isn't this dangerous?  Doesn't the MS 6.0 eval version quit working at some point or become disabled somehow?  We're seeing differences in the executable behavior between the app built with eval version of MS 6.0 compared to the original built with MS 1.0 - but we haven't positively correlated this with the MS version.
Menchar
(7,513 Views)
Now I see that when I installled Measurement Studio 1.0, it only offered to install examples and help?  At least that's the only optional items maybe.
When I run M&AE 4.2, it does not show Measurement Studio 1.0 as having been installed.
And the start menu doesn't show Measurement Studio other than readme, help, and utility programs.
Add and remove programs show ComponentWorks++ as installed, but show no Size or usage information.
I'm not sure MS 1.0 has been successfully installed, despite being able to get past the SP3 requirement popup.
Thanks for any help on this.
Menchar
Message Edited by menchar on 04-14-2009 11:27 AM
(7,509 Views)
Hi Menchar,
Another thing to check is that the "latest" registry key in the same folder has a value of 3 rather than 6.  Let me know if this helps!
Message Edited by Al B on 04-15-2009 06:04 PM
Al B.
Staff Software Engineer - TestStand
CTA/CLD
(7,483 Views)
