Measurement Studio for VC++
VS2010 & MFC Legacy support Compile error
Hi all ,
I'm using VS2010 Ultimate with MS2010 And the C++ MFC Legacy R1.
I'm tring to compile a simple program ( first time with all the support)
I'v included the path library.
stdafx.ccp :
#include "NiUiComponent.h"
#include "NiDAQmxComponent.h"
using namespace NI;
I'm getting this builed error :
1>c:\program files (x86)\national instruments\measurementstudiovs2010\vcnet\include\niexception.h(466): error C2440: 'default argument' : cannot convert from 'const char [1]' to 'LPCTSTR'
1>          Types pointed to are unrelated; conversion requires reinterpret_cast, C-style cast or function-style cast
1>c:\program files (x86)\national instruments\measurementstudiovs2010\vcnet\include\niexception.h(466): error C2548: 'NI::ThrowNiOleException' : missing default parameter for parameter 2
1>c:\program files (x86)\national instruments\measurementstudiovs2010\vcnet\include\nicommoncomponent.h(48): fatal error C1189: #error :  UNICODE not supported
any idea's ?
Kobi Kalif
Software Engineer
(6,796 Views)
Accepted by topic author Kobi_K
Hello -
When using NI MFC components, you must not use unicode libraries.  Measurement Studio MFC support does not support unicode, only multibyte.  You can fix this in one of two ways.
  • When creating a new MFC project, you can deselect the "Use Unicode libraries" checkbox.
  • If you have an existing project, you can open the project properties and select "Use Multi-Byte Character Set" for the "Character Set" general configuration property.
One of these solutions should resolve the build errors for you.  Please let me know if it does not.
NickB
(6,792 Views)
