Measurement Studio for VC++
Visual C++ & Bluetooth Serial Comm
I have a bluetooth device sending ASCII at 9600 baud. From my PC
device manager my "Bluetooth Communication Port" is (COM5). The
bluetooth device wizard created the "Serial over Bluetooth link" for
outgoing and incoming as COM14 and COM15 respective. Using hypterminal
and using COM14 (I'm surprised I don't even need to set the baud rate
and handingshaking for this port), I'm able to receive the data from
bluetooth device fine. In the code of my MFC program I can't open
neither COM14 nor COM15. I can only open COM5 which doesn't appear to
be receiving the data. Why is this? What is the difference b/w
"Bluetooth Communication Port" and "Serial over Bluetooth link" in the
Device manager? Thanks in advance.
(7,313 Views)
Can I ask what device you are using?  Also, are you programming this using VISA?
Eric K
Applications Engineering
(7,279 Views)
