Measurement Studio for VC++
What files do I use for setup project with NI measurement studio?
I want to create a distribution of my project which uses the CNiGraph. What files/modules must I include in my Setup project?
I am using the Setup and Deployment project option that comes with MS Visual 2002. WinXP.
(3,667 Views)
What version of Measurement Studio are you using? That will help decide what you should do for redistribution.
Jeff
NI
(3,667 Views)
Measurement studio version 6.0 with upgrade to .NET.
(3,667 Views)
You should be able to find the Merge modules necessary on the CD. You should be able to find them under Redist\MeasurementStudio\MSMs, and other dependencies from Redist\Third-Party.
The MStudioUI merge module should provide the necessary files for adding CNiGraph to the deployment project. Jsut right click on the project and select Add Merge Module.
Jeff
NI
(3,667 Views)
