Measurement Studio for VC++
What is EDVR error 0xE1060077?
I get this error after a long run of reading from instruments such as Agilent E4416A, Agilent 8665B, etc.
(3,144 Views)
I wanted you to check a couple of things. Under devices and interfaces in Measurement and Automation Explorer, when you highlight your GPIB device, right click on it and click on NI 488.2 troubleshooting wizard and check to see if either of the tests fail.
Also, make sure you have the latest driver versions for your device
There is also a knowledge base KB 1DREQIQA GPIB Error codes and solutions which talks about all the error codes and it has EDVR error code explanation too.
Check to see if the solution seems apporpriate.
Incase you have any further questions, feel free
to email back.
Good luck and have a great day!
Koninika
National Instruments.
(3,144 Views)
