Measurement Studio for VC++
What to use instead of ClassWizard
I am using Measurement Studio 7 for Vis C++ and MS Visual Studio .Net 2003. I notice there is no ClassWizard option under the "view" menu as mentioned in the NI getting started example. How do you get past this? I believe ClassWizard was removed in Vis Studio .NET 2002.
(3,504 Views)
I believe you want to use Add Variable.
Can you let us know what getting started example you are you referring to so that we can fix it?
(3,504 Views)
It depends on what you're trying to do. Most of the Class Wizard functionality has moved into Class View in Visual C++ .NET. You can get to Class View by clicking on View in the main menu, then clicking Class View. Check the context menus in Class View for what you're looking for.
- Elton
(3,504 Views)
Sure,
Its http://www.ni.com/pdf/manuals/323063a.pdf
located at
http://digital.ni.com/manuals.nsf/websearch/CF10F3D194D7219E86256A6200590855?OpenDocument&node=3769_US
Salman
(3,504 Views)
