Measurement Studio for VC++
Where do I find nimdbgu.dll ???
I have created a VC++ application from an existing Labview program. I can get it to compile but when I try to execute it, it says it cant find "nimdbgu.dll"
where is it ??? how do I find it ???
-roman
(5,575 Views)
I believe that is a NI-DAQmx dll, which you can get with NI-DAQ 7.0.
- Elton
(5,575 Views)
Thanks Elton
I am using Version 6.0... and I looked thru all the "cab" files on the cd and I did not find nimdbgu.dll
Any other suggestions ???
(5,575 Views)
NI-DAQmx is new in NI-DAQ 7.0 and would not be in version 6.0, so I think you will need to download NI-DAQ 7.0 and look there.
- Elton
(5,575 Views)
mmmmm
Is there any other way to then get a program to run under VC++?????
(5,575 Views)
I'm not sure what you mean. Is there a reason that you can't install NI-DAQ 7.0 on the machine that you're trying to run your current application on?
- Elton
(5,575 Views)
