Measurement Studio for VC++
Whether there is an upper limit on the parameters of the DAQmxReadAnalogF64 function
float64 data[200000]={0};
DAQmxReadAnalogF64(taskHandle,-1,-1,DAQmx_Val_GroupByChannel,data,200000,&read,NULL);
The function will crash if it has more than 20k parameters or an array of more than 20k, is there an upper limit to this parameter, or is there a better way to receive a signal and extract 80k data
Thanks for the reply
(918 Views)
Use dynamically allocated buffers (malloc) instead of stack allocated ones!
Rolf Kalbermatter  My Blog
(363 Views)
