Measurement Studio for VC++
Why CWiGraph yAxis labels are earsed when moving the plot
I have two same dialogs with CWiGraph control. When moving the one over the another, the yAxis labels on the bottom dialog, minimum value and maximum value, are earsed to half. Only two labels are earsed, anothers like xAxis and caption are all fine. I just attached the snapshot for this problem.
Thanks.
(6,419 Views)
mliu,
what version of Measurement Studio are you using and what version of the CWiGraph Control are you using. I attempted to reproduce this with Measurement Studio 2009 in Visual C++, CWGraph Control Version 1.6.
Raj
(6,397 Views)
Hi Raj,
I use MeasurementStudioV60 in NI_DevelopmentSuite_2001, but I don't know the version of CWiGraph control, how to find the version of controls?
mliu
(6,393 Views)
Hi Raj,
I got another problem. Like I mentioned before, I have two same dialogs with CWiGraph Control. If I open one dialog, move the cursor over the plot area, or open two dialogs and only move one dialog cursor, everything is ok. But if I move one dialog cursor and jump to another dialog to move its cursor , later whenever I move either cursor, plot area background become blink. When I move "Major X only" style curosr, a lot horizontal wide lines in dialog backgrond color blink on the plot area. I never found this problem before because I usually use one CWiGraph Control in the application.
Thanks.
mliu
(6,388 Views)
Hi mliu,
Unfortunately the version of CWiGraph control and Measurement Studio you are using are very old. I cannot reproduce this bug in either CVI 2009 or Measurement Studio 2009. If this was a bug in an older version, it has since been fixed in the newer version. It is unlikely that we will revisit the older version and patch it up. I would recomment upgrading to the newer version of either Measurement Studio or CVI depending on your needs.
Raj
(6,371 Views)
Hi Raj,
Ok, thanks.
mliu
(6,369 Views)
