Measurement Studio for VC++
Why the AI (voltage) is always 4.9987 for PCI 6036E using Ni-Daq low-level functions, such as ScanSingleBufAsync.c?
I am not very experienced in the field of DAQ.
So I cannot solve the following problem:
This problem can be overcomed using Labview.
But my C++ code worked before at previous
workplace. Now it can also handle noise signal,
but not the real one.
Any help is really appreciated.
(3,500 Views)
Hi Paulliu,
What voltages are you trying to read? Are all of them above 5 volts?
If you can properly read voltages below 5 volts, but it rails on voltages above 5, you have an incorrect gain setting. You will need to insert an AI_Configure function to set up the proper range. Check out the following KB's:
http://digital.ni.com/public.nsf/websearch/D4211BD64091F8C486256D980006DA8D?OpenDocument
http://digital.ni.com/public.nsf/websearch/8D621EE9861552DB86256EA8007C3C45?OpenDocument
(3,500 Views)
Thanks. I later found out that the voltage do change
when the signal changes significantly.
The default setting can handle a voltage upto 10 V.
My worry resulted from the different behaviours of
these low-level function from Labview program which
always outputs non-constant voltage, even the
real signal does not change.
(3,500 Views)
