Measurement Studio for VC++
Would it be possible to plot discontinuous line on CWGraph?
I need to plot a discontinuous line on a plot. Basically, if the amplitude of the waveform is possitive, I need to draw a line at 1.0. If the amplitude drops to below zero, I need a bland line (no line). What would be the easiest way to implement this?
(3,003 Views)
There's no way to do this with a single plot. The closest that you could do to this would be to create a plot for each line segment. You may also be able to do this by making the value NAN for your 0 values.
- Elton
(3,003 Views)
